Mugabetown - Whoretownin' At It's Worst.
Isn't Europe fun!
Boz. that sucks, I would assume heater hose
GT6 installing now.....seeyas some time in the future (and sunday)
yes hence y I love it so much :)
Also noice re GT6
been awake, missus got me up with the promise of some nookie,
only to tell me to do the dishes and clean the lounge ........
WTF is this false hope shit !!!!!
That is BS! There are few things in life better than waking up to a morning gobble.
Nor looking forward to cleaning the car today gonna pull half the car apart to fix up some trim that hasn't been sitting properly for a while now.
At least your cars are able to run :-P
Anyone got a spare seat for a photographer I've got coming along? Work and the car gods have f**ked me over. I can get him to the meet (in my oh so classy Astra) but I have to bail early so he'll need a lift to the powerhouse mid afternoon.
just evil that is just evil.......
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
