Mugabetown - Whoretownin' At It's Worst.
guys i used to work with on oil rigs would work 12 on 1 off ones fully retired at 24 after 7 years on the rigs.
Gallardo in the shed for his troubles
I have a mate the same, He retired this year at 32 after 10 years of work as a mining engineer in a gold mine, at first he was in Kalgoolie then he was in Mauritania, worked 3 weeks got 2 weeks off where they would fly him to wherever he wanted and was on 500k a year for his troubles. He has been more or less everywhere in the world and owns 6 houses outright in Perth and Kalgoolie. He is pretty much just living off rental income for as long as he likes.
mine, silver 33 gtr , white wheels and missing rear wing end caps
I do think i recall seeing it out there. Hard to remember a lot of them. So So many cars. But luckily a lot of ppl's cars arent setup for continuous track use and half the cars where parked in the pits cooling down so the track was never too busy lol
what do you mean you need to upgrade your stock radiator when puting out 3x the factory power? and now you tell me i need to add an oil cooler and possibly a trans cooler too???
madness.
  • Like 1
i was speaking to a former truck driver, has his own house and mostly paid off by his early 20's
he was saying you need to seriously think about how/if you can handle killing someone when you hit them, because its not a case of IF its a case of WHEN. he got out of it not too long after he nearly killed a guy that drove through a stop sign without stopping to check traffic.
madness.
even in stock form the cars still not built for full track use.
one happy laps was enught for me to go back to the drawing board on my car
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
