Mugabetown - Whoretownin' At It's Worst.
New lease of life to the 13 year old gram lights... new stickers. was going to hang off putting them on because i wanted my rims painted buuut itll be ages before i do that and Ill end up painting them the same price as the sticker
I finished on the 13th and go back on 22nd of jan :)
about to start painting engine covers and calipers over the next few days...
I want Ants over to hold my hand :P
no you don't mate. As always the key is preparation and painting in a clean and isolated (sheltered) environment and watch out to not overspray (clean the nozzle after each spray coat) and don't spray to close to the object.
preparing for my first xmas alone in 23 years woo...
ill probably get pissed and watch porn :P
http://www.youtube.com/watch?v=2PLbblfZNRg
Mr ants. is there any huge drama removing the cam cover?? or do i need to remove the CAS ?
if so help! :P
Edited by ibrox90
  • Like 1
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
