Mugabetown - Whoretownin' At It's Worst.
So.......for once that I want to play for just 10min on PS3 (GT5) and I made it clear to my wife 'just ten minutes' (I rarely play it)
I don't even get five and my older daughter is deliberately crawling all over me and my wife tells me 'I don't want to have the PS3 there......move it back in the computer room'
FOR f**kS SAKE!!!!!! I WAS JUST ASKING
FOR TEN MINUTES..........JUST TEN!!!!!!
all this Ls1 in R33 is making me want to do a v8 skyline conversion more and more.
Nice VK56 out of a current infinity, retrofit the AWD system somehow, 320kw's and no turbo lag at all...
Is this because you heard how sexy mine sounded the other day when it lumped into the meet lol
  • Like 1
This would be an acceptable V8 to put in a Skyline.
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
