Mugabetown - Whoretownin' At It's Worst.
straight off the ATO website nice one Tony. This ^ is also why this option may not be a viable one..........as the level of audit risk is significant and although would not benefit a tax advantage it from it, it would create unrecoverable time charged............for something the client would not understand.
Nope. From Deloitte. As if trust the ATO. :-P
I am aware of the power that 101 Motorsport car makes lol...
No traction isnt joyous when you are trying to keep it.... Mind you no traction does get the bitches I've heard
when you can do 400m power skids without ever touching the brakes, the bitches be moist.
Happy Valentine's Day to all the sexy beasts out there....
All the not so sexy beasts can suck a fat one.
The good old Hallmark holiday... lol
Aimee & I have been dating for 5-6 years, still never given each other a single gift for Valentines Day. This year aint going to change
Yeah... I got Chants something small. Tyler and I bought her a charm bracelet for Xmas. So buying a present for any occasion now is easy as! :-P
alright mate. Just got a valentines day from my wife...........she doesn't know it but I have one for her two with chocolates to suit ;)
And you sir?
Body chocolate.............
I used to buy my GF jewellery, however she hardly ever wears any so I gave up
Ha, I aint buying a thing lol...
Buy a single rose, a Rembrandts cd and body choclate... The rose may die, and you may run out of body choclate but The Rembrandts will always "be there for you"......
http://m.youtube.com/watch?v=nzQWmAwNNCw
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
