Mugabetown - Whoretownin' At It's Worst.
Hi Mr President.
Ready for another epic week?
Damn straight. Yourself?
Got the first part of the training catch up this week. Meeting with a few boys for drinks to get a few things underway! Feeling pumped. Should be an awesome way to finish the week.
For interests sake, if I was to buy a non rego'd car from NSW, that happens to have had an engine swap along the line somewhere (engine number not updated), when I get the car to QLD and in prep for QLD rego, should I notify them of engine number change before I get the mobile roady guy out? Or? From what I remember, the mobile roady guy compared engine numbers before signing off on Cara's zed (which we bought from NSW).
Enlighten me
SKIDS!!! Morning all
Morning Nark. Was thinking this morning, since you're so anti-nissan, maybe you should get brakes from the new HSV. The bus goes past a Holden dealer and I saw the brakes and just thought, why would they need so much stopping power on something that produces SFA horsepower?
Enlighten me
You would need to notify them before the mobile RW guy comes out.
Don't you work for TMR? :P
I thought that might be the case, however, since the car isn't on the QLD books, what would they update exactly?
Hell no I don't work for them, just in one of their buildings ;)
You raise a valid point. They would probably create a shell of the car on their systems and note it accordingly so that it's updated at time of rego - if they ran like an effective corporation.
Sure sure.... :P
I duno dude 435kw needs some stopping, also I didn't cook my brakes on Sunday. I only cook them with you guys cause it's like track day as opposed to line ups
I didn't even think you raced anyone all day lol... Just cruising
good stuff. I'm flat out with deadlines galore this month!
Enlighten me
Had this with Kathryn's car engine had be swapped tmr was not informed
Rodie guy will jut right it down and you go in and regestrring it if the ask you just say if has had a engine replacement, not swap but replacement with the exact same engine
They won't care if it's the same as the old
  • Like 1
Cool, you make it sound nearly too easy lol
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
