Mugabetown - Whoretownin' At It's Worst.
Hi Mr President.
Ready for another epic week?
Damn straight. Yourself?
Got the first part of the training catch up this week. Meeting with a few boys for drinks to get a few things underway! Feeling pumped. Should be an awesome way to finish the week.
For interests sake, if I was to buy a non rego'd car from NSW, that happens to have had an engine swap along the line somewhere (engine number not updated), when I get the car to QLD and in prep for QLD rego, should I notify them of engine number change before I get the mobile roady guy out? Or? From what I remember, the mobile roady guy compared engine numbers before signing off on Cara's zed (which we bought from NSW).
Enlighten me
SKIDS!!! Morning all
Morning Nark. Was thinking this morning, since you're so anti-nissan, maybe you should get brakes from the new HSV. The bus goes past a Holden dealer and I saw the brakes and just thought, why would they need so much stopping power on something that produces SFA horsepower?
Enlighten me
You would need to notify them before the mobile RW guy comes out.
Don't you work for TMR? :P
I thought that might be the case, however, since the car isn't on the QLD books, what would they update exactly?
Hell no I don't work for them, just in one of their buildings ;)
You raise a valid point. They would probably create a shell of the car on their systems and note it accordingly so that it's updated at time of rego - if they ran like an effective corporation.
Sure sure.... :P
I duno dude 435kw needs some stopping, also I didn't cook my brakes on Sunday. I only cook them with you guys cause it's like track day as opposed to line ups
I didn't even think you raced anyone all day lol... Just cruising
good stuff. I'm flat out with deadlines galore this month!
Enlighten me
Had this with Kathryn's car engine had be swapped tmr was not informed
Rodie guy will jut right it down and you go in and regestrring it if the ask you just say if has had a engine replacement, not swap but replacement with the exact same engine
They won't care if it's the same as the old
  • Like 1
Cool, you make it sound nearly too easy lol
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
