Mugabetown - Whoretownin' At It's Worst.
Martin 1, Leopard 0.
Had to get the alternator out of the bastard, thought for sure that would be an engine out job, but turns out it isn't! Was quite a battle but I got it out in the end, although there was literally millimetres in it, any worse and it would have been engine out for sure. Not quite sure how I'm going to get it back in :S but will cross that bridge when I get to it.
Also, turns out she has Takata belts, who knew?
How are both the cars Martin?
Leopard will probably be up for sale very soon. Alternator is dead but I'm replacing it, tried that silicone spray trick on the seat belts but it didn't seem to help.
Wedge is going fine. Clutch pedal got noisy the other day but I sprayed a f*ck tonne of silicone spray on it seems to have sorted it out :). Still using oil, haven't looked again to see if it's leaking or burning it though. Probably retire her from daily duties soon so that will give me a chance to sort it out
Re mystery oil burning, In my old R32 i was always losing oil slowly, turned out it was an oil seal in the turbo that just let little bits out constantly, it was a small enough amount that it would burn up instantly and not cause noticeable smoke but it was enough to almost empty the damn sump if you forgot to keep an eye on it!
Does anyone know if the pistons on R34 GTT brakes (F&R) are the same size as Z32 brakes? I know the rotors are different sizes... Not sure about the acutal pistons though...
they are the same Tony
Wish my car came with brembos :(
Will have to get a set of bigger brakes sometime this year. Unsure of direction to go. Kit out of china, Brembo's off of r34, Evo Brembos... lots of choices.
brembos from other cars ie R34 GTR are a poor upgrade...........save and get a big brake kit........I'm not a fan of Chinese brakes hence why I have AP Racing 6 pot brake kit
Brembo F50 / GT kit, Endless, Trust / Alcon all quality brakes but expensive
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
