Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
IMO R33 GTR brembos are overpriced.
Sometimes yahoo has bargains on BBK.
Very true. I got mine for under 1000 front and rear. Above that and they are not worth it and the China kits would be better.
Recently (yesterday) heard a few examples of the calipers being incorrectly machined and not fitting. It is a long way to send heavy ass brakes back because they don't fit!
Lots and lots of people have had a lot of success with these kits though!
I really wanted to get a Megan racing kit out of the US, but the American guys wouldn't sell to me because they had an Australian distributor and the Australian distributor would sell me any because he wanted to sell me Alcons instead.
These would have bolted up to my car, but noooo he claimed he had to machine up this that and the other thing to make it fit, lies
http://www.enjukuracing.com/products/Megan-Racing-Front-Big-Brake-Kit-%252d-Nissan-240sx-5%252dLug.html
My mate picked up a Brembo kit for his alpha which is a 4 piston 326mm rota front and 2 piston rear, which was sent from Italy. He paid like $650 including delivery. its amazing how stupidly expensive brembo brakes for Skylines are, considering a good set of rotors and pads on the standard brakes are nearly as good.
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
