Mugabetown - Whoretownin' At It's Worst.
We have been pretty happy with the outlander thus far. No off roading yet tho.
Awaits 400 photos of the bogged outlander... Had an uncle try to take his on Fraser that was an interesting day lmao
Small "4wd's" are not for 4wding, most are incapable and just to Danm low
Unless you Usualy have lots of experiance with 4wding you can run into troubles
But I will say. Suzuki's they go hard off road
Anyways I have talked to ants about purchasing some parts and I have found a new direction for my car with the power side of things
This means forged bottom end :D
Interesting definition of 'real 4x4' you have :P
Low range, traction control, ladder frame chassis and same clearance as your navara. And at least it won't get stuck spinning diagonally opposite wheels in the air like yours will :P Edited by Bunta
Oh and stock it is on the low side, but nothing a cheap lift cant fix, and we are not into 'off road' where you go out and find places to get stuck and break shit, we just want a car that can do the fire trails ect.
I like where this is going :)
Morning folks.... Well events yesterday afternoon/night werent what I expected. Got a call from a mate at midday asking if I want to accompany him down to Matty @ Pits to get his car on the dyno just to check the replacement cam he got in is fine. I thought hell why not I finish work at 1:30pm it will be a good drive.
Got there at 3pm and and we got the car onto the dyno..
Matty played around with it for a while and fixed up a few things here and there. It came to about 6pm and was doing a few final power runs...
Knock Knock.......... who's there? Spun a bearing in the last 10 mins on dyno...
After many profanities were used Matty ended up dropping us at the train station and we got the train back to Sandgate then got a lift home....
Got home at about 10:30pm and then up again to start work at 5:30am...
Tired Scott is tired..
You went all the way down to see Matty Spry and didn't swing pass to say hi????
I also went to bed late paying for it now :/
Sorry to hear about your mates car Scottie.
What power did it make before she gave way?
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
    • $350 for a skid pan is a joke, cost of living is definitely more in NSW 😂
    • pretty sure that is about $1M for a 100mx100m slab....I'm gunna need some help on that. I do have the space and understanding neighbours though
