Mugabetown - Whoretownin' At It's Worst.
Sounds like a good idea. I am not privy to this motor vehicle you are assembling. All i know is it has a Crank trigger setup [Which im learning more about and jealous of lol] and now e85 with a good fuel setup. Sounds like a cool machine in the making
Its not going to be anything too special, the crank trigger is really just about reliability, after nearly 10 years of cars 'going out of tune' i just want a car that I can turn the key and kick it in the guts HARD every time with out fear of frigging knock lights ruining the fun! At he moment I am capped to running only 14psi with little to no timing, it made 306rwkw then so I am keen to see what the set up is actually capable of with a stable timing signal.
And if I dont like that I will build the RB28 I have wanted for the last 6 or 7 years!
yeah Bunts car should kick some serious bogan V8 ass once she's all done :P
Ha ha I doubt I will cross paths too often with any rigs matching that description, happy laps grand prix is not really my scene!
Is those figures on pump 98? I made another 100hp when i switched to e85 and only added like 3 psi
Strippers FTMFW... Especially Lesbo shows.
This is true
Yeah that was on 98. I think the physical flow of my turbos will be the limiting factor, they are only babies so I think they will be incapable of pushing more air at 350ish kw, though they have been modified from stock so their limit is a bit unknown.
Ants, what's that whisky recommendation website that you use? Also, have you tried Macallan 12 or 18 YO?
Its this website mate http://www.smwhisky.com.au/
Yes, I have tried both Macallan 12 and 18 fine oak and also tried the Macallan Sherry Oak. I also happen to own both ;)
Does it come recommended?
well its Macallan mate. She's like the Nike of single malts its very good stuff but I find the price hard to justify.
Its why in fact Macallan went down the path of introducing the fine oak range because production costs are lower using american oak barrels (bourbon) rather than sherry oak barrels, however even their 18yo was like $189 IIRC.
My thoughts are as follows:
Fine oak - cheaper than Sherry oak and is very fruity, makes your mouth water / dry and then releases beautiful flavors like vanilla, raisins and fudge
Sherry oak - very exy but my favorite but caramel galore. Could really go without that artificial coloring IMO but the tastes - at first its very spicy, but after you have drank a dram you get the following flavours, burnt cookie / creme caramel, spices like cardamin, orange peel and a hint of wooden smoke - truly amazing mate.
you can make your own recommendation but I think you know what to go for now.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
