Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
We should have a party at Mikes and see how much of the backyard we can fill with Zeds and Skyrine. If the Zeds win, we but him a beer. If the Skylines win, we put an RB20 in one of his Zeds. :-D
what was wrong with the kit Grego?
Gary's recommended kit includes the following:
Front Eibach Main Springs
Rear Eibach Main Springs
Rear Eibach Helper/Tender Springs
Colil Over Conversion Kits x 4
Front Bilstein Shocks
Rear Bilstein Shocks
Front stabiliser bar adj
Rear stabiliser bar adj
Caster Kit
Front Camber kit
Rear Camber Kit
Front Bump Stops
Rear Bump Stops
Rear Subframe alignment kit
I'd like to hear your thoughts Grego as I was just about to get the funds organised for the above?
Shocks, springs, sway bars and bump stops are good. Everything else i would be going adjustable arms (you can get adjustable arms with rubber bushes rather than spherical bearings). The sub frame alignment kit http://www.whiteline.com.au/product_detail4.php?part_number=KCA349 why would he recommend that rather than just replacing the 20 year old bushes?
Also what about the diff mounts, rear lower control arm bushes, bushes in the rear hubs/uprights and more i can't think of now. There are a lot of parts he has left out.
Hey scotty, calipers are upside down afterall
Yer, thought it was. Ah well ill switch them over next time they need bleeding.. They still work really well
Also, so much zed, so little shed
Holy Zeds Batman...... I like the fact you've got so much love for one type of car. Any chance we will see one of these at the dyno day this weekend or happy laps??
rb20 might at least give more engine room for other mods. May stop the process of taking the engine out of a zed to do an oil change lol
 Share
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
