Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
That many?
New car is fast. Fast car is fast. Nearly scary fast. Will be even faster with bigger injectors and more boosts. Injectors are pretty much maxed out atm.
Edited by MagicMikeZ32
How many kw's are you guys making at 4k rpm?
Out of interest...
no efffffin idea Mike.
-5s on standard 26 are very sluggish and would not be surprised if a Honda Civic goes faster than me at 4Krpm
Out of interest...
Mine was 225kw last time. That was its base tune with the new ecu still limited to 4k, hoping to get a lot more when i can run some timing and boost
What turbos Bunta?
Makes for a fast streeter making that much so 'low' in the rev range...
HKS 2510s with a few select twists courtesy of MTQ, and yeah its pretty much perfect for street duties.
Edited by Bunta
*WOW* great numbers that is @ 4k rpm
Yep, pretty happy with it, will see what the final result is in the end.
2510's are pretty small...
What kind of peak numbers are you looking for?
yeah they are small, as for peak figures I couldn't really care less, I just want a huge midrange, peak figure so far is 306rwkw at 14psi with very little timing, given the 'bastardised' nature of the turbos I have no idea what they are capable of.
I understand why the need for a stroker would suit you.
yep! that way you can have midrange with out needing to keep the turbos small!
VH45? Great low and mid range. Whack a turbo on to it for top range and all the scissor throwing at dirty LS1....
 Share
    • Dose unofficially becoming R33 god
    • I would rather buy from aliexpress than whatever that "shop" is. Avoid like the plague.
    • Sounds like, to me, if you do some geometry calculations, you can fit a hoist in there
    • New dampening settings are much nicer or crappy roads, I've also noticed no difference when throwing the car around on smooth twisty roads In other news: Idle hands are the devils play things, or, more correctly, my typical while we're in there 5hit, and too much time on my hands with online shopping  Some new purchases for the 2.5 swap Fancy pants new 32mm triple flow radiator, because the old radiator is old and needs to come out for the 2.5 swap anyway Gates fancy pants water pump, because recommended with the new radiator  Plus a new silicone coolant hose kit,  because old hoses are old And a sump baffle thingo, because while I won't track the MX5, I'll probably track the MX5, maybe, probably......but, while we're in there anyway, as the FWD 2.5 sump needs to gets replaced with the RWD 2.0 sump, so, yeah I am loving driving the MX5 around everywhere, the poor old Bogan Cruise Ship hasn't really moved in months
