Mugabetown - Whoretownin' At It's Worst.
It is cheap, they can be had for 3 parts of f**k all now.
Errr.. Not so much. Maintenance on them isn't cheap at all. You're still facing $10-15k for a 15 year old car that requires a fair amount of servicing and upkeep. That's similar pricing to 33 GTRs, so not cheap.
No matter how you slice it 10k - 15k is a cheap car. Out of interest maintenance wise, what is expensive about them?
All this talk about crank trigger.......and I too know about them benefits thanks to Bunta.
Thinking I now need to invest into one.....for reliability's sake
You are in the position that few of us are though, where everything is new and there is not much movement there, really you should be ok for a while, but if you do want one hit me up and I can get one built for you!
http://sethgodin.typepad.com/seths_blog/2014/03/what-does-its-too-expensive-mean.html Have a read of that and you'll see where I'm coming from.
Gear box is stupid expensive, however that's once every 100k km - hopefully. Plugs are all iridiums (could be platinums now that I think about it), coil packs are about 20% dearer than standard skylines, parts are rarer hence more dorras (window motors, fuel cap release motor, seat motors etc), sway bars are about $350 + shipping from the states because they're difficult to source here, exhausts are more expensive when you include stupid frieght rates. Overall, it all adds up for less performance.
interesting......
You would also change plugs a lot less, be kinder on your oil (not needing to cool turbos down) coilpacks should last due to less heat ect ect. The only one I can see is the extra electrics crapping out but that should be a long way off, I was speaking to Grahame the silver fox and he was saying his costs him fuark all.
interesting......
Ya Rly!
Ya Rly!
Mine's done about 120k km, which is when everything starts f**king out. Hence my level of frustration right now. Oil is still changed every 5k km. Plugs every 50km, which is probably next year. Coil packs are on their way out. Graham has also done significantly less ks than mine has. I think he's sitting at 70k-ish from memory.
Oh, and the bushes are starting to f**k out and need to get them done. and diff feels like it's on the go - not sure though.
All of this whilst saving like a flamin mongrel for a major investment which is due to be finalised in Sept - if all goes to plan. :rant:
Every car shits its pants around then, the little Mazda is about to start costing me money too damn it! But in June it will no longer be my problem so thats ok.
The frustration is amplified when the performance isn't there yet the parts cost more. It's a fun position to be in.
Oh well, you will know for next time!
wasn't aware that most of the stuff had to come from the states - which is what bugs me the most. So in short, it is not cheap. A $15k car that costs a mint to run isn't cheap.
I think the key difference here is your definition of a mint and my definition of a mint is quite different, everything you mention is, to my mind, typical of every car. However I must also say that I don't consider my car to cost a fortune to run either, even when I did drive it daily.
In short I guess I am saying "Damn son, Yo a whinger!" :P
Which is exactly what the link to Seth godins blog described.
Also, I'm going to be in a position in 6 months time when all my assets will be scrutinised, so I'm a little concerned.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
