Mugabetown - Whoretownin' At It's Worst.
afternoon all
Haha probably!
I other news I managed to swap the r33 exhaust I had for a r32 gtr exhaust that actually has a mid muffler in it. I don't have to mess around moving hangers this way. Quieter unicorn here I come!
good to hear, so I guess you never got around to seeing how easily it would fit?
Looking at new shells, should I stick with r chassis is or look at s chassis
glad your Okay man. shit to hear about the car though.
Yeah I will stick with 33
Found a new shell getting it thursday
nice!
LS powered, goon balloon and shit apprentice?
BURN!
afternoon all
Hey mate.
The shape was right but it would have required moving hangers. I was able to swap for a HKS hiper which I had on my blue r32. So it was easier and was the exhaust I was actually after!
Looks like it takes a while for you to awaken the beast ;)
hahaha just a bit. This is what happens when people want to do rolling starts at 55-60kmph. To slow for 2nd but too quick for 1st
Here is one against a silver 33GTR, Spoke with the guy after and it ran a 10.56
I want a carbon one though :P
Anyways reshell is planned for the Easter long weekend
Asking the boss tomorrow if I can use the shop
Open invite, anyone wanting to help is allowed to turn up just inbox me. Any one who helps will receive free beer next time I have kesh and we are at a dinner and chat or anywhere beer can be had
  • Like 1
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
