Mugabetown - Whoretownin' At It's Worst.
Ah ic... easy as then ;)
Yeah it should be. I've already filled out the form including majority of the 'office use only' section lol
they should pay me to do it.
This is probably something i should do too... Car has only been back on the road for 6 months
Not a bad idea Scottie considering QMR and QPS like to make sure the engine number matches to their records................oh and the fact that the maximum penalty for not advising them of this can exceed $6,000 :woot:
So merely chump change then lol
Can also request a 'donor' engine number from them, in the case of blocks being skimmed so as the number is no longer visible etc.
All you need to do in such case is fill in the form and list reason as 'engine block decked' and provide evidence (receipt for such decking or similar).
Who wants e85 and p100 discount vouchers!!!
I have some here for united with a 5c a liter off and they expire tomorrow
Each voucher says max of 100liters
They also have a free can of Pepsi with them
I have 2 for grabs
Just gotta swing past and grab them
Text me on 0432799909
awww too late, and no car that needs em :(
afternoon all, weekend of no internets should have been good for car work.......but instead spent fixing internets. how many modems do I need to buy in my lifetime?
shit Bodo. I've only ever had one modem and it's done it's job.
Although you probably ass rape your download limits compared to mine which would explain why you go through so many modems
Aye, having a radiator is a good thing.
I always had one just thought that since im making 600rwhp+ its about time i upgraded from the standard one
nice. You coming to Easter cruise?
Ps I know your workin but a sickie will help :D
Unfortunately no chance of a sickie. New radiator post in build thread needs your attention Ants lol
that sux Scottie. Will have to be another time
Build thread replied to
You never disappoint Ants!
Currently having trouble with re locating the Oil Filter. Trying to avoid doing the whole thing again. Damn the workshop mounting it on the fan shroud, where it now doesnt fit
so you are trying to relocate the oil filter again?
Yes. When the young apprentice did it, he mounted it on the side of the fan shroud. Whilst outting the radiator and shroud back on the screw came loose. To put it back in that location I would have to take the filter off the plate and thus spil some oil. Trying to relocate it to an easier location. Trying to get it to replace the washer bottle spot. But the lines arent playing nice
that will be subject to trial and error Scottie.
As depending on the length of the lines will determine your new location.
My oil filter relocation kit is mounted under the car next to the sump.
Best mod ever. As all the oil expels down naturally after you remove the oil filter (thanks to gravity) and makes minimal mess
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
