Mugabetown - Whoretownin' At It's Worst.
Ah ic... easy as then ;)
Yeah it should be. I've already filled out the form including majority of the 'office use only' section lol
they should pay me to do it.
This is probably something i should do too... Car has only been back on the road for 6 months
Not a bad idea Scottie considering QMR and QPS like to make sure the engine number matches to their records................oh and the fact that the maximum penalty for not advising them of this can exceed $6,000 :woot:
So merely chump change then lol
Can also request a 'donor' engine number from them, in the case of blocks being skimmed so as the number is no longer visible etc.
All you need to do in such case is fill in the form and list reason as 'engine block decked' and provide evidence (receipt for such decking or similar).
Who wants e85 and p100 discount vouchers!!!
I have some here for united with a 5c a liter off and they expire tomorrow
Each voucher says max of 100liters
They also have a free can of Pepsi with them
I have 2 for grabs
Just gotta swing past and grab them
Text me on 0432799909
awww too late, and no car that needs em :(
afternoon all, weekend of no internets should have been good for car work.......but instead spent fixing internets. how many modems do I need to buy in my lifetime?
shit Bodo. I've only ever had one modem and it's done it's job.
Although you probably ass rape your download limits compared to mine which would explain why you go through so many modems
Aye, having a radiator is a good thing.
I always had one just thought that since im making 600rwhp+ its about time i upgraded from the standard one
nice. You coming to Easter cruise?
Ps I know your workin but a sickie will help :D
Unfortunately no chance of a sickie. New radiator post in build thread needs your attention Ants lol
that sux Scottie. Will have to be another time
Build thread replied to
You never disappoint Ants!
Currently having trouble with re locating the Oil Filter. Trying to avoid doing the whole thing again. Damn the workshop mounting it on the fan shroud, where it now doesnt fit
so you are trying to relocate the oil filter again?
Yes. When the young apprentice did it, he mounted it on the side of the fan shroud. Whilst outting the radiator and shroud back on the screw came loose. To put it back in that location I would have to take the filter off the plate and thus spil some oil. Trying to relocate it to an easier location. Trying to get it to replace the washer bottle spot. But the lines arent playing nice
that will be subject to trial and error Scottie.
As depending on the length of the lines will determine your new location.
My oil filter relocation kit is mounted under the car next to the sump.
Best mod ever. As all the oil expels down naturally after you remove the oil filter (thanks to gravity) and makes minimal mess
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
