Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
twas indeed, looked good. Got dark real suddenly yesterday arvo
Ive decided to trailer my car to the EFI tomorrow to avoid the chances of the po po pulling me over during the Easter Break....
Also contemplating getting rid of the plazmaman plenum in favour of something that sits a little lower
mostly highway to EFI, you'll be right :) just watch that right foot....they get heavy after driving for a while.
What do you want for it?
$875? lol
Not something i want to risk at the moment. with car events being so close. Knowing my luck there will be a HWY Patrol car lurking
$875? lol
$8.75 it is. Shall pick up off you at the cruise. :-P
This guy. He knows.
What do you need it in the workshop for?
Tune. Long story short, Half moon indicator on cam snapped, not exactly sure if I got the CAS on in the exact position in should. Went to dyno day. They reckon it was leaning out up top. Ive also had a bigger exhaust put on last week.
Think its best if I get it on the rollers, even if its just to make sure everything is ok. If we can squeeze a little more out of it then its a plus. I wont care even if it makes the same power. I'l just be happy that i know its all running right
lets see.....,bigger exhaust, corrected / optimized tune....,was making 588hp on prior tune......you will def make more poawa bro
I agree Ants. My only goal though it to make sure its running good for Powerplay. Oh and i guess getting a dyno sheet of me breaking into the 600's would be cool
You are a smart man Scotty, I don't care what everyone else says, I rekon you're alright :D haha
Haha I dont believe you for a second. I've seen the shifty eyes you throw around. I need to see your Zed collection one day
when you coming down tomorrow Scot?
Spending more time on the skyline this arvo
Plenty of pics will be uploaded tonight
Already have people lining up for bits from the old one
Gotta love having people lined up for parts before they are available
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
