Mugabetown - Whoretownin' At It's Worst.
Yeah. Doesn't matter about shaft play etc, they just need it to be in reasonably working order.
They just need the housings to not be f**ked, can even have all the blades missing.
So after an evening of pondering intercooler stuffs, i think i may have figured out the "but stock gtr cooler is good for 400kw's!" thing.
A few people have commented that they can't do back to back power runs on the dyno with them, so it seems like the stock one is plenty big enough of a heat sink for a little bit of a squirt, but then its way to oversaturated with heat to keep the job up afterwards.
The question is, is an ARC one going to be any better (only 10mm thicker, but better fin design?) or should I go for a bigger one down the road instead of hanging out for an ARC one...
I have an ARC. I have no heat soak issues. In a GTR coolers defence driving is quite different to being on a dyno in front of a fan. Intercooler would be low on my priority list
You're quite right, you'll be getting more airflow on the open road. However, there still has to be a limit to it, although that's going to be depending on a lot of factors. ambient temp, power, how much power is being used, how often, and for how long. I honestly don't know the answer and short of sticking a temp sensor into the outlet of the cooler i'm not sure i will know.
However, that being said, Sean did recommend a new cooler. And i'd like to get one now that will be good for 400kw down the road. So I dunno.
I'm running Chinese quality FMIC costing $300/$400
As Bunts said tis a lower priority than other mods on you're list
rule of thumb goes like so
300rwkw stock cooler ok
Anything over get a bigger cooler as the car / turbos will generate more heat that's what I used
Car was making 285kw's on 98, so I dam well hope its making over 300 on E85... I think i'll upgrade now.
I've been making up a bit of a spreadsheet of all things i want to do to the car, with prices and whatever other info I want to put in there, just so i can organise my head and jot down stuff so i don't forget it.
Shits expensive. UP to 25K already.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
