Mugabetown - Whoretownin' At It's Worst.
Cheers Ants, Couldnt download on the phone, but works on the computer, damn phone!
Looks like a good list Pete. Few things to consider, Link g4s are a good computer and can be had under a grand if you keep an eye out, for the oil pump see if you can get a hold of billet gears to go in the stock pump, cheap and so far totally bomb proof in mine. what manifold is costing over 2k? :0 the Crank trigger kit costs around $700, you will need an ATI balancer too.
Yeah, all parts are still up in the air.
Wolf is only 1200 bucks for the ECU IIRC, the extra cost is for the actual in line ethanol sensor for the flex setup. But ECU is still very much up in the air.
Oil pump gears might be an idea actually.
Manifold for 2K is one of the sexy sexy Fullrace ones. May not end up going down that route of course, but sexy.
Yeah the full race manifolds are porn. Fecking exxy though especially if you end up getting them coated etc. I saw this one the other day which looks pretty good. Local, twin gate set up already coated etc and much cheaper.
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=89_90&products_id=2447
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
