Mugabetown - Whoretownin' At It's Worst.
Since you guys are talking ridiculous stuff, check this out
http://www.skylinesaustralia.com/forums/topic/427987-epically-awesome-enginespartsbuilds/
We were talking about this last night funnily enough. And probably as you were posting it.
Titanitum everything!.
My build is going to be nowhere near extreme enough to warrant that unfortunately.
Everything warrants everything, I don't need a 2 way cusco diff to roll down the highway, I don't need a lumpy pig of a cam to sit in traffic, but you do it anyway :) (so therefore you need titanium)
Side note: I do need a procharger to go and play with the big boys
I don't need to have a "get that last 1%" track mentality on a street car either....
also, hump day!
nah who am I kidding, every bit you can get is better. I just wish I could afford titanium everything's.
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
