Mugabetown - Whoretownin' At It's Worst.
Noel just got 680 hp out of his car today. After crapping his precision turbo afar not making the desired numbers with it he Changed to a MTA 900 and just pissed power. Pretty interesting!
Thought precision were supposed to be ok...
from a reliability point of view no doubt, but the power production part was the most interesting, they had to push hell out of it to nudge 600hp.
what version precision turbo was it Bunts?
64/66
Scott made 588 no problems (not on EFI dyno. Will be interested to see what scotts does make on said dyno)...
Definitely think there was something not right about the 6466 Noel got unfortunately. It struggled to make over 600hp then finally seized up on the dyno. Time will tell what i can get out of mine
Simon32 made over 700hp atw using a Precision 6262 Turbo on a standard RB26 using a standard GTR box.
Just sayin
Noel's turbo musta been le f**ked
I've not driven a700hp car but I do know the jump from 450 to 512 I thought was quite a bit then again from 512 to 588.. But it's hard to make an informed call till I've been there really
Then again all setups are different. 700hp in some cars I would be a total different feeling to 700 in another setup
700hp on a track car is doable but you want to make damn sure reliability and suspension and transmission is also up to par to cope with that power.
Is Noel's car a GTR?
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
