Mugabetown - Whoretownin' At It's Worst.
Sorted, grandma is goin to do it
Exemption is not sorted and this isn't working towards it, this is because I'm sick of having a car there doing nothing and can't take it anywhere. This way I can still take it to places for work to be done and drive it for work, and still attend event if someone will take it
But there is another work around with the exemption I'm going to give a go. If it fails. Then it is there untill opens but will be driven more
Now to buy a solar trickle charger
  • Like 1
How long until you get your opens?
I was wondering why that minor thing would stop you from fixing and entering, but of course, engine out
lawl smartass :P
Usually a battery out job at least, but since mine is in the boot it should be easy enough.
Also starting the twin 2.5inch intake piping upgrade, and plenum pull also for 1000cc injectorz. Can't finish that until I get plenum gasket from the US. $20 gasket. $85 shipping FML
Exhaust staying the same, already twin 3inch.
Currently running single z32 maf (which is pretty much at its limit at 5V) and stock 2inch (x2) intake piping. So going twin maf and 2.5inch intake piping upgrade which should reduce restriction pretty well. 500hp on nismo 555's basically maxed out also, kill the 2 known limiting factors in 1 go.
I suspect next limiting factor will be tyres and driver haha
lawl smartass :P
farkin lul....at shipping cost
why driver?
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
