Mugabetown - Whoretownin' At It's Worst.
Not was I was after so back to plan A.
Need a huge screwdriver like Pete did?
nope. I has filter a handy oil filter relocation kit.post-5053-14009771432774_thumb.jpg
Sits underneath next oil sump and in front of front diff
You need just the right sized tool and its fine tbh. Will be putting that relocation kit in this rnr. Ran out of time last one between going out on the Monday and having a lazy day on the Tuesday.
The curse of the gtr plenum. Tbh I didnt find it that bad changing mine in the stock location.
that would be an absolute PITA + more PITMFA to change
all them little hoses underneath and nuts
weak
extended sump on yours Ants?
nope not yet.
all standard.
I couldnt find a smaller size bottle oil for the additional top up (for the oil cooler) so I had to procure another 5ltrs of semi synth oil
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
