Mugabetown - Whoretownin' At It's Worst.
Well I went to boarding school so sort of left at 12, BUT my family has well over 100 years of history there, so all of the influences in my life are from the area.
So you learnt english at a boarding school :P
I did go to school for 7 years before that, and got an academic scholarship, so really I would think I knew much of it before I got there! My mum was a teacher, so I learned most of it from her, but she was also from Gatton! Nick and his Goonie mates are giving the place a bad name! :P
Though I must say my brothers wife and kids do a good job of that too! Haha
Too much stuff in a legnum engine bay.
Removed most of it though, thing is only hanging by a pair of engine mounts for tomorrow
SAU needs to do more group mechanic days though
We do.... It's called a reshell... And subframe bushes.... And anything that I really do on my car I invite people to come look at and learn
I'm gonna try coax the boss into letting greggo use the hoist. Feel like a super shit bloke that he can't
You just need to get on your knees and 'beg'
who has access to hoist or something to lift the dirty 33 up. I need to do exhaust manifold gasket ......... will pay !
looking to do it on the weekend of the 14/15th if possible
dude. Get some jacks and ratchet spanners and you are all good
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
