Mugabetown - Whoretownin' At It's Worst.
I just want some cheap 4/5 stud wheels to throw some track tires on, so that I can run them on either car
Now, probably wasting my time, but I have these lying around (tyres not included, unless you want to pay a lot extra)
Do you like roller blades? (narrow is good for skidz..., ask anyone who spent too much on an underpowered 86) :D
Have some 17x7" 45mm offset wheels with 4/5 stud pattern
Enkei 'Orsh Varents'
(the worst one, some nicks on the others though)
Recently repaired and refurbished by Depulu Wheels (courtesy of a suspension shop who doesn't know how to put wheel nuts on the right way around),
Then re-rashed by a clumsy Legnum driver (who never once rashed them himself until after they were refurbed :'( )
And incase you think they are just for 'fagnums', here is one of the only pics of the same wheels on the internet
(no idea if offset is the same though)
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
