Mugabetown - Whoretownin' At It's Worst.
Anyone have a contact for cheap SuperPro bushes?
Fulcrum with club discount. Just don't get them to install them :P
Andy.... I'll take em!!!
Shit bloke :(
Now, probably wasting my time, but I have these lying around (tyres not included, unless you want to pay a lot extra)
Do you like roller blades? (narrow is good for skidz..., ask anyone who spent too much on an underpowered 86) :D
Have some 17x7" 45mm offset wheels with 4/5 stud pattern
Enkei 'Orsh Varents'
Hmm... I actually don't mind the look of those for track wheels. But I would have to run massive spacers and run skinny-a*se tires on them :(. How much are you chasing for them, no tires?
Edit: also, are fagna's 4/5x114.3 stud pattern?
Anyone have access to a paint booth?
Or a shed/something that can be used as a paint booth?
by some plastic drop sheets from Bunnings for like $1 each convert your garage into like a spraybooth.
wait......
wait.......
pls tell me you have a garage right?
How many f**ks do you give about the quality of the job? I assume this is to paint the pinny?
You can spray it in my old mans paddock if you want. He even has the compressor and hoses.
I do but not able to turn it into a spray booth
I give zero f*cks, but not sure if old mate I have lined up to do it will want to do it in a paddock... will check though.
He also has a spray gun you can probably borrow to do it yourself if you want. You'll just have to clean it afterwards.
Cara's brother put a propper booth in his shed.
It is an epic shed.
Can I use it in exchange for cash/beer/reacharounds?
I can't paint to save my life
They're overweight Evo's, so yes.
So, an hour and a half before i have to leave and i've yet to pack... enough time to do O2 sensor or leave it until i return...
While photographing my spare parts for selling them I noticed this. This may be a problem.
its a cheap fix. Whoever you sell them injectors to should be smart enough to get them cleaned and flowed tested of which they will also get the caps replaced. Just sell them as they are Pete
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
