Mugabetown - Whoretownin' At It's Worst.
Probley true about leaving it at the bottle shop but I have half a bottle of jw double black that needs to be drank and I duno tastes better on ice
Probably because it's blended shit.
All walkers are blends, you should be able to buy like sample bottles of expensive scotches so you can tell if you like them
And be extension all walkers are shit...the only acceptable walker is the King George the 5th bottle.
What! No Ice... I like ice
all good dude. It's mostly up to your taste, and ice can help tone the harshness of some whiskies
Mike however, understands the reasons you don't add ice to quality SM Whisky
It's not a quality single malt lol
I have blends around a lot as drink of choice is a rusty nail ie drambuie,blended scotch and a couple drops of lemon over ice, f**king delicious
I will try this someday - and I'm pretty certain that my thoughts will be something like this
'Tastes like JW blue label'
Tastes like a nice smooth Blue Label, thats the best way to describe it.
Yes well like I said I'm not going to drop $100+ on something I don't know if I like the taste of
My mates and I have dropped about $5,000 on scotches. Anything in the higher price range usually tastes nice.
Well what's a scotch in the 100-200 dollar price range that's worth drinking
What sort of flavours do you like? I'm quite partial to the Glenfiddich range ans am yet to find a bad one.
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
