Mugabetown - Whoretownin' At It's Worst.
I still have not received my group cert. was posted on the 11th, so if the postie gets here before 11 i'll have it to take back to site with my maybe.
that sucks. Both my group certs arrived in the mail by the 7th. I lodged tax on that day and received it on the 15th
Guys, log on to MyGov.com.au and get your tax return pre-filled.
That's one way to see if your individual pay. summaries is recorded with the ATO as majority employers are submitting their PAYG electronically
Nothing was Prefilled in there in regards to income summaries. did hear someone mention that you'd probably want to wait until August if using Mytax though. Might try it again in a week.
MyTax works fine as long as you have all the accurate information available. It is best to wait until your employer either gives you your PAYG Payment Summaries or you know for a fact that everything is pre-filled accordingly.
#@Ants would know this better than I, however i thought my Law your employer has to provide your group cert within 14 days of July 1st.
In Pete's case his employer sent his my mail 11 days after, regardless of whether Peter receives it or not inside the 14 day window
Thought that final day for PAYG summaries was today due to the 1/07 falling on a Monday.
Ants would know. Alternatively, instead of doing it yourself, get a proper accountant to do it for you. A good one is definitely worth more than the fee you pay - especially if there's some intricacies involved.
  • Like 1
correct, unless the entity is closely held that's what employers should be adhering too.
However, that's not always the case.
ATO is now cracking hard on this though and issuing late lodgement penalties more frequently
It could also be because the ATO now only accepts electronic lodgement via business portal for those that prepare their annual reports via an approved accounting software and are having difficulty embracing this method (although I certainly welcome it)
My returns are still very basic at this stage. once I get more assets etc and its a little more involved I'll pay someone
Replacing some of toothless' fluids in preparation for laps of happy on Sunday. Keen!
why is it toothless? do you have a dragon or something??
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
