Mugabetown - Whoretownin' At It's Worst.
I think I will do the same and finally put some full synth oil in the R
I'll put in the stuff Zane bought, but because it's different to the stuff we used to use I have no idea what it is :closedeyes: I haven't had to pay any attention, it's usually magically already at home when I need it :yes: I have an oil supply fairy, his name is Zane... And if I do go to buy it then he gets it off the shelf and I just pay because otherwise I get distracted and we never leave haha!
  • Like 1
bah ha ha ha ha you're a classic Mel
Haha well we used to use Motul 4100 Turbolite (at least that's the one I think it was), but then it was hard to get as most places stopped stocking it so changed recently. Which is why I don't know this one :) I think it's a Nulon oil that we have atm but I am pretty sure the next stuff will be Penrite... All I know is this stash has to be used first so Zane will be glad I am doing my oil this weekend so he can buy the Penrite next time :P
all good oils IMO -
I've always used Mobil - exy stuff I know but its never failed me ...............................yet
all good oils IMO -
Yeah, there are so many and everyone will tell you something different about each one! I remember when I went in to a store in Canberra looking for some of the Motul and the filter I needed, couldn't find it, told them what I wanted then snapped my biscuit because they tried to convince me I was an idiot and it was the wrong oil, they looked at the commodore outside and assumed that's what I wanted it for and I was like you f**king tool it's for my damn skyline now do you have the oil I want or not?
cAndy! The only place I seem to be able to get an x181 is online. Are they that good that I can take the risk without trying one out?
Just googled it. Jeebus! Look at the meat on them!!! It's like the old MRF bats.
I too am a penrite lover. When I can't get royal purple that is.
Turbo lite sux balls
Didn't have any issues with it, until it became difficult to buy.
I went to superlap a few years ago and one of the royal purple promo girls scarred me for life, it was horrible to see... So, so, horrible!!! Should not have worn that outfit and to make matters worse, should not have gone commando in that outfit! I pointed it out to the boys to share the burden and I think they were also scarred for life... The other one on the other hand could have sold it to me if it wasn't for her oompa looma sidekick... That right there is what I am reminded of every time I see royal purple...
Did you just turn the topic onto cricket bats?
that depends - if you keep punching holes through engine blocks no amount of oil is gonna help you :P
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
