Mugabetown - Whoretownin' At It's Worst.
Yup.
I don't like domestic flights let alone the thought of international, the thought of flying overseas makes me nauseous then a few unfortunate events relating to flying overseas just add to that, needless to say, could not fly Malaysian Airlines even if it is just unlucky at what has happened... But I am sure you will have an awesome trip...
We are contemplating USA end of next year, early 2016... Even then I am tempted to stop in Hawaii for a day or two so that it makes the flight a little bit shorter...
Also... Who can suggest some places I can get a custom colour rattle can made up so I can paint some shiz?
Yeah It pretty much cant be bad, no work for 4 months, hard to go wrong really.
Thats probably better, I wouldnt mind doing shorter trips to different places, but Anna is doing courses while we are over there so it sort of has to go that long. I would like to do like 6 weeks there, 6 weeks in europe, 6weeks in South Africa, ect ect. but yeah at the end of the day I have 6 months of leave built up and I can afford to take it half pay so there is plenty of scope for those other things down the track!
Sounds like a plan! I want to do Europe but doing to start with USA/Canada and then another time go and do Europe (mainly Finland and Germany because relatives over there). I want to go to Japan but not sure about anywhere else in Asia or africa etc.
Autobarn
That's what Bodo said, I have no idea if they will be able to get it close to my Metallic pink/purple pearl since it's two colours on my car to make it what it is but if they can get it even remotely close I will be happy...
Martin let me know of a place in Geebung that may be able to do it and I've heard there is somewhere in Strathpine but not sure where. Gives me a few options at least, hopefully one can get close...
Paint matching in a can will never be 100%
Doesn't need to be, just needs to be close so I can cover the white and grey primer until I am ready for a full spray :)
main thing is they need to be able to scan a sample. not just find a paint code
Yeah, I can take my fuel cap off for them to scan otherwise I have a tin at home which is a fairly close match and was used previously on a door handle when my car was broken into.
Japan aw yiiiisssss!!!
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
