Mugabetown - Whoretownin' At It's Worst.
Yes, I would like to take this opportunity to thank Pete for coming over to help me with a massive dump, couldn't have done it without you... :P
Here are some photos, (suppose its about time I make a build thread though lol)
Here is all the shininess in its final location:
68f763ea-4390-4c34-aea4-cb26c629b682_zps
Old vs new: 691a06ef-7622-4146-8d36-ac6db647780e_zps
This will probably cause the best improvement, the old throat was LITERALLY a 1" square passage! (Fck you Mitsubishi):
c555186a-d5a9-40d0-ae6e-6de41928e2a3_zps
I did the front last weekend, was considerably easier...:
e96ed7fd-39d9-42fa-9927-da5cc092a400_zps
cm'on do Magna Wagon build thread already
Jeez Pete that's going above and beyond the call of duty for friendship mate! :P
  • Like 1
A friend of mine works at the APS centre in Melbourne, posts up photos of cars he tunes. Last night he posted this...
10499601_311436359018487_698837254331416
280hp AFTER a performance tune. That's cute. Makes you wonder why you'd even bother spending that much money if you're going for performance?!
Spent bout 2 hrs in nistune today.
Swapped ecus over between pnk and silver bullet. Just to rule out the ecu as my issue. Both ecus in caras car work fine. Spent remainder of the time tinkering with mine. Think I am getting somewhere. Idle is good. Next step is mounting the wideband and going for a drive ;)
    • this is the reason we have more than one child right?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
