Mugabetown - Whoretownin' At It's Worst.
I want led highbeams already. But they don't make any to fit r32s (yet) supposedly.
also I need to wire it up so my hid low beams stay on when high means are activated.
Led or hid? Led would be too dim
Yeah intercooler is huge. Bar has been hacked up to make it fit. Interesting on the led department ... only car I have seen to run led headlights was the holden effjay concept thing and it had a monstrous cooling system behind a 20ish watt single led
Here is another potato quality picture that shows how bright it really is, very spotlight-like beam, which combined with the HID lens lights I already have gives a very full spread. Even if I've only fitted one side so far.
Looks ok. Might have to find myself a second set of 33 headlights if they work out.
Longevity will be the deciding factor, these are cheap ones from eBay. Also, all led headlights like them use a tiny fan on the rear to cool the aluminium heat sink, I have run them for 5 mins in a go with no significant heating, but if the fan goes or lets moisture in they will probably die... Will keep you posted
