Mugabetown - Whoretownin' At It's Worst.
We've been over this before....
ECU isn't compatible. Plenty of servos around. Why bother.
orly?
The reason I ask is because of this
Dalby Ethanol Bio-Refinery under threat of closure. - See more at: http://www.unitedpetroleum.com.au/united/news/news-item/news/2014/02/17/dalby-ethanol-bio-refinery-under-threat-of-closure-#sthash.i1z8FdYx.dpuf
Almost didn't stay up for the race last night. Glad I did :), but boy am I going to pay for it today. Struggle street... :S
Pretty sure I will be going home this arvo to watch it online... I like 4 or the top 5 so I will like the race at least :P
Yeah. And by carrying jerry can problem solved. In fact I can fit 2 of the 20L ones in easily. It was really more of a question of do i stop at every servo along the way or do I take the Jerry can so I can stop less to save time, As I was trying to cram Leyburn and Kawana into one day. My range is limited however, yes, but honestly I don't think that i'll need to go further than a bit of planning will allow at any point in the future.
Part of it is also that i'm still trying to get a handle on the economy of the new Fuel. I was getting 17-18L/100km on the first few tanks but these were city and spirited driving, so max 400km from a tank. From T'bar>Leyburn>home>Logan servo on Saturday I averaged 14.7L/100km which is much better, almost 500km/tank range there.
Once I get the O2 sensors in hopefully it'll be even better again!
I travelled to and from bribie island though so there was some km's involved. I left my house with a full tent got to the BBQ point with half tank, threw in my 20L then drove home and once I got there I had half a tank again. A lot better than I expected really
Guess it's less painful paying $1.25 p/litre
  • Like 1
Mitsubishi ASX is a POS but fuel efficient... Just don't try to overtake, or corner at a normal speed on a slightly rough road... Needless to say it was over 10hrs in a boring car on the weekend...
What ecu are you using Pete? Nistune?
How will narrowband O2's help with e85?
Better off removing closed loop IMO and tuning for a targetted afr at cruise ;)
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
