Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
Day 1 of our new structure at work, goodbye job satisfaction! *waves*
That bad huh?
My work restructures all the time, in other words everyone else decides to do less and I get even more :dry: And there are only 3 people in the office!!!
Yeah they split our functions into 2 teams. Assessment and compliance. We used to do both and it was good for our careers, have really well rounded skills. Now you are either glued to a desk or dealing with dumb complaints all the time.
so, you should now say that you 'specialize' in either Assessment / compliance Andy
That's a possibility I guess. Being overly specialised in my field isn't always a good thing though!
that is true.
However, you know that you can and have been working with both components up to now.
just don't forget that
Also spotted a white Stag with an R34 front end conversion, had a GTR badge on the grille but I didn't see if it was a GTR front end. Pulling onto Samford road on the range between Samford and Ferny Grove.
standard 34 front does not fit, needs the GT-R front to fit the wide track
seeing as this is now the spotted thread, saw PEte today heading gold coast bound on the M1 in the GT-R, gave him a toot as he drove past me doing 120 and didnt even get a response !
Slacker
Slacker
What a rude prick...
 Share
    • I'm still not sure what you are trying to acheive, but I wanted to clarify something about Lithium's response to your question...   Only within certain limits. All of the examples Lithium gave were of detuning for a particular reason. Before the engine/turbo/wastegate combination has hit full boost, you can't increase it....the wastegate is shut and the turbo is pushing as hard as it can Once the combination has hit the target (controlled) boost, you generally have full control over whether it makes more or less boost, because it is being limited/reduced from its potential. This is generally done by controlling the wastegate In the top end, with an undersized turbo, it is possible you won't get to your target boost anymore if the turbo is choking up. In this case you cannot increase boost any more without changing the setup. No change in cost compared to any decent build, other than tuning time to get the engine to make less power than it is able to at a certain point
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
