Mugabetown - Whoretownin' At It's Worst.
Check that you didn't bump loose the fuse in the engine bay, you were messing around in that area yesterday after all.
I actually pulled it out after I noticed the 4wd light was. same problem occurs after I put the fuse back in.
turn engine on everything ok, then a few seconds later the 4wd light comes on.
will get it fixed this week if time permits it
Lucky my mate had spares. Box is back together but still down the Goldie. Have to wait for some new parts to arrive before it goes back together anyway.
Aparantly billet options are available, but we will see how it holds up again first
standard box Mike?
Usually only throws codes if propper f**ked
allegedly you can adjust the TPS if to the required voltage.
so will give it a crack.
proly will just get a new TPS anyways from Kudos as its only $79
