Mugabetown - Whoretownin' At It's Worst.
I'm leaning towards the 33. So all I need to do now is save $20,000 and part the SS out for go fast bits money.
honestly should you do it, just fix the rust in boot of SS and get rid of it in one go.
No point having a carcass lying doing nothing
Then save and buy what you want
Plus the issue of it having no compliance or build plate and the paint being in average nick. Also I think you underestimate the extent of the rust...
Highflo, injectors pump tune etc, is what, 5K?
GTR is 20K, boost T and its making probably 30-50kw less, but has AWD, (more weight) and suspension will be stock, not adjustable. and for 20K you're not getting a pristine one unfortunately. Parts don't break any more than a GTS-t will, but when they do more money potentially, and upgrades do aswell. Twice the turbos, twice the diffs, etc.
End of the day look at how much your saving and how quickly, and if you're prepared to get a loan to get one.
Or, do HA and instrumentation courses and come work out here for pornstar money.
I know, this is why I'm not sure what I want. Would be starting from scratch again.
Yeah, dunno about the lifestyle tho :P
I was in the same dilemma, though i wasn't as far along with my old car at that stage. In the end though I figured everything i was doing I would just have to do again, so i traded up.
Buy this one? link
Buy this one? link
I know, I haven't really spent that much on mine yet.
If I had the money right now :P Perhaps I should go do $6,000 worth of courses and join you in butt f**k nowhere.
Its an interesting life for sure. Also, unfortunately, the work is starting to wrap up on this project at least, so there's no guarantee even if you do do the courses i'm afraid, pretty much every industry is like that now though.
But yeah (for the tradies), 10 hour days, work 20 days straight, travel, 6 days off, travel, work 20 days straight, repeat. Stay in camps literally in the middle of nowhere, but at least the rooms are decent, food is buffet, gym on site and the like. But yeah it gets lonely, you do get days off during the week to make up for it but most people are working on those days, which is good for going on drives or getting stuff done but not for keeping in touch with folks really. Honestly don't know how people with kids do it, but the financial rewards must be a good part of it.
all I hear is excuses :P
GTR for those who like parking them in garaghes...or rebuilding 26's
stick with the GTST for track car imo......having said that, a 33 GTR would be gorgeous. the one that Pete linked is f**king swoit
good evening all, house keys on monday!!
getting a double garage floor paint kit thingy from Bunnings straight away and painting the floor up before loading everything in :)
new house keys needs a GTR for that new garage
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
