Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
Its an interesting life for sure. Also, unfortunately, the work is starting to wrap up on this project at least, so there's no guarantee even if you do do the courses i'm afraid, pretty much every industry is like that now though.
But yeah (for the tradies), 10 hour days, work 20 days straight, travel, 6 days off, travel, work 20 days straight, repeat. Stay in camps literally in the middle of nowhere, but at least the rooms are decent, food is buffet, gym on site and the like. But yeah it gets lonely, you do get days off during the week to make up for it but most people are working on those days, which is good for going on drives or getting stuff done but not for keeping in touch with folks really. Honestly don't know how people with kids do it, but the financial rewards must be a good part of it.
That's my issue, everything is wrapping up and there is already a lot of qualified guys out there.
you have to fight for what you want these days Mike
Don't give up because things are wrapping up.
I would see it as an opportunity to find a new and better career or position
There will be more work, eventually, probably plus i'm sure a lot of the folks are on 457's and will probably be kicked out soon once the job ends, so less competition for the next one... You'd really have to want to work out here though to start onto it now.
Depends what you think your prospects are doing what you're already doing (I have NFI what sort of money normal sparkies are on in the city), might not be worth the risk if you're doing alright in here, particularly considering that the gov is pushing to have more houses built as the next construction boom to take over form the mining boom, you might already be in the right spot to take advantage of that (start your own company?)
About $60k a year, not much around tho.
Was always planning on starting my own company.
GTR for those who like parking them in garaghes...or rebuilding 26's
stick with the GTST for track car imo......having said that, a 33 GTR would be gorgeous. the one that Pete linked is f**king swoit
I've built more 25's than 26's
The gas industry is... interesting right now. Construction has peaked on the QGC project for sure, but its not a solid drop off, ok we're done everyone all 15000 of you go home kind of thing. Then you've got the other big players, Origin, Santos and arrow. I'm not 100% sure where they are at, though i've heard that Origin at least still have a fair bit of work to do for the next few years. Then there's always the option of work over in WA or up in Darwin on the LNG plants there. More medium term though i'm not sure about though. As all the work is sub contracted and sub sub contracted out etc there's always a lot of moving and shaking with the individual companies doing the actual work, which can be a good or bad thing depending if you're working for one that gets shafted or looking for a job and one gets hired and told to put on a dozen new people etc.
Your right Pete, all are heading over to the West or to Darwin on the gas works. I go to Mackay every 3 weeks and the coal industry is struggling big time. I know a lot of guys that are being laid off, and having to move away as there is limited work.
In saying that Pipeline work is planned for Moranbah to Gladstone and if Abbott Point finally kicks off it would be good for the region.
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
