Mugabetown - Whoretownin' At It's Worst.
I've used this guide for removing the hicas on both my 32's and it works great and is the easiest way to stop the warning light showing on the dash.
http://www.sau.com.au/forums/topic/410492-r32-hicas-removal/
HICAS warning light
Many people have said that locking HICAS causes your steering to get heavy, but they simply haven't done it properly. There has been NO change in steering feel with any of the cars that I have done. The only problem is the fact that the HICAS warning light comes on (because it's not there...). This can be solved by cutting the warning sender wire on the HICAS computer or removing the warning light's bulb from the dash. I prefer to cut the wire as it's quicker, easier and if you for some reason lose power steering fluid, it will tell you when your resevoir is low.
The HICAS computer is underneath the parcel shelf, it is to the right of centre (when looking in from the boot). Unplug the smaller of the two plugs in the back of it and then cut the green with white trace line wire. You can also just leave the smaller of the two harnesses out and it does the same thing, no ill effects and no HICAS light.
HICAS warning light
easy peasie
How is everyone?
I did some landscaping yesterday, my muscles hurt... Thankfully not as badly as I thought they would, I can still function haha! But even my hands are sore! So what do I do? Arrange for 2m3 of crusher dust and pebbles to be delivered today so I can do that along with the other garden edges I need to do :P Never learn!
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
