Mugabetown - Whoretownin' At It's Worst.
Don't suppose anyone knows the part number of the GTR spoiler rubber/gasket kit?
this is all i've been able to find, but getting it from the states seems excessive, will probably pop down to the local nissan parts shop later today.
Edit: Bolt was loose...
was going to say, pretty sure Ants just did a full detail and replacement of his 32GTR spoiler. Cleaned it all up and replaced bolts and gaskets etc. There should be part numbers etc in his build thread. If not just PM him I'm sure being the numbers man he is, he will remember.
Morning Ants.
How goes the Ant Eater?
she goes well mate. I need to replace the nitrogen canister for the 4WD so am on a mission to get that resolved soon.
Sooo much I want to do with the GTR so little disposable income and time
I feel your pain about disposable income. I had to get a second job to feed the addiction
this ^
Check the condition of the stay brackets Pete as they tend to corrode
Good call,
Figured out what i did wrong with part number, didn't add the 05U00, thanks for documenting Antz!
The bolt that was loose was seriously loose, eg finger tight, so will see if that has stopped the leaks for now...
Anyone got a slide hammer I can borrow?
This sounds serious. Is this for the tissuebox?
Pete, if you're gonna rid yourself of that wing, I know someone who'll happily buy it from you, ME! ;) I figured you're not, but it was worth a shot.
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
