Mugabetown - Whoretownin' At It's Worst.
Don't suppose anyone knows the part number of the GTR spoiler rubber/gasket kit?
this is all i've been able to find, but getting it from the states seems excessive, will probably pop down to the local nissan parts shop later today.
Edit: Bolt was loose...
was going to say, pretty sure Ants just did a full detail and replacement of his 32GTR spoiler. Cleaned it all up and replaced bolts and gaskets etc. There should be part numbers etc in his build thread. If not just PM him I'm sure being the numbers man he is, he will remember.
Morning Ants.
How goes the Ant Eater?
she goes well mate. I need to replace the nitrogen canister for the 4WD so am on a mission to get that resolved soon.
Sooo much I want to do with the GTR so little disposable income and time
I feel your pain about disposable income. I had to get a second job to feed the addiction
this ^
Check the condition of the stay brackets Pete as they tend to corrode
Good call,
Figured out what i did wrong with part number, didn't add the 05U00, thanks for documenting Antz!
The bolt that was loose was seriously loose, eg finger tight, so will see if that has stopped the leaks for now...
Anyone got a slide hammer I can borrow?
This sounds serious. Is this for the tissuebox?
Pete, if you're gonna rid yourself of that wing, I know someone who'll happily buy it from you, ME! ;) I figured you're not, but it was worth a shot.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
