Mugabetown - Whoretownin' At It's Worst.
Eagle Rods,
ARP rod fastener kit.
ARP head & main stud kit.
Wiseco 0.20? o/size forged pistons & Molly rings.
Balanced crank Nissan bearings
Heads reconditioned O/S valves, with 3 angle valve work
JWT 500R cams, [ 2013 ]
New Hyd lifters, [2013]
New HD vtc springs [2013]
New Nissan timing belt + pullies [2013]
Turbos Garrett GT2871R.
AMS MaxFlow cast ion manifolds
New oil / water lines, hoses.
HKS blow off valves.
3? dumps & exhaust system from turbos back.
53mm Alum radiator.
1250lb clutch balanced with fly wheel. [H/D].
Under drive pulley.
Apexi AVC-R Elect boost controller.
Nistune ecu.
New coil packs & plugs.
New Injector plugs.
New 02 sensors.
Short throw manual shift. [stillen]
One piece tail shaft new unies, Tail shaft loop.
New gear box & engine mounts.
New 550hp Wilbro fuel pump, filter,
New Nissan AFM unit.
Stillen large SMI.
800CC Sard injectors + pressure reg.
New brake master cylinder.
New clutch slave cylinder & hose.
Apexi pod air filter.
HID low beam lights.
New air compressor & condenser.
Re Upholster interior and seats.
98+ spec manual gear box [ 2012 ]
Exedy 5 puck HD button clutch. [ 2012 ]
Kyb adjustable shocks front and rear with eibach springs
r34 GTT 310mm front brakes
Adjustable front camber [super-Pro]
New bearings in Alternator.
New Nissan water pump
4 Point harness drivers seat only
Aparantly made 469rwhp @ 18psi previously in WA, but I don't trust the guy who did that tune. Has gone 11.59@120. PLENTY more in it if you so desired to get those turbos into the meat of them.
Edited by MagicMikeZ32
Yep. Inside and out it is very clean. Except the wheels, I'd change them to something jap. It's got some Koya's or something on it now. 275 rubber up the back tho.
I would buy it myself if I didn't already have 2.5 in the shed, and I knew what was going to happen with my job after september...
Gday Antz! yea mate going well now working away.
Yea things kinda grinded to a halt when I got made redundant, was out of work about 12 months so car just sat collecting dust. took it out a few times but cant race it hard until I replace the PFC and fit a custom crank trigger. Else the cars going strong.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
