Mugabetown - Whoretownin' At It's Worst.
Afternoon sir. Does that mean that motor and turbos and everything will be sold in order to start afresh? Few vultures may already be circling around that block.
Yes, most likely.
I was thinking of keeping it but I'm thinking that the next build will most likely be stroker
Yes, most likely.
I wonder who will pick up that motor. 2.8 stroker or 26/30 Ants? Choices choices choices.
I like 2.8 sound of things but everything is trending to 3ltr+ now which I personally makes things more complicated than what it really should be.
But I will once again do my homework first and then take it from there.
The big block boys have been saying it for years "there's no replacement for displacement". The cost of building a 26/30 would be punitive compared to a RB28 I would have thought? Or you could just go a Rb34 ;)
BTW I purchased a bottle of Laprhoaigh last week (the select cask)
That shit is so peaty that you want to punch your grandma in the face!
F me!
That stuff is nice! Although you aren't a peat fan from memory. It's ok, I don't think he takes it personally. :P
Yes, can't beat cubes hence Nick lol
Yes, I actually wouldnt mind getting another bottle which is called the quarter cask - 48% abv and has some really good reviews but yeah Peat and I don't get along as well as Sherry does.
Quarter cask is one of my brothers favourite drops. I too quite enjoy it. For your palate, I do recommend the Dalmore range or the Aberlour. Good stuff! Had Dalmore 12 earlier tonight and enjoyed it.
the QTR cask has scored 96 points. But yeah for me I like sweeter whiskys. Doesn't mean I don't like peated malts though
The Dalmore 12 is insanely sweet.
The Macs and Dronachs are one of my favs
But I like all kinds of whiskies
Yes, it's about tastes and also the mood you're in. Having said that I'm always keen to explore and expand my knowledge by trying other whiskies.
The Dalmore cigar malt is nice and the 18 I must try one one day.
Arberlour is on my to do list.
Right now though on the hunt for some Japanese malts :)
Japanese hey? Very pure crisp flavours. Which in particular?
any mate.
I've recently purchased Nikka from the barrel and that is just unreal
The best nose of a blend I've ever had and tastes magnificent.
Last night I had (a whee bit too much) Laphroaigh Select cask but that's because I really enjoyed that smokey aftertaste
Think I'm going to buy that QTR cask now, as I think I'm hooked on it now lol
The more refinement that goes into these peaty and smokey whiskies the less it tastes like an ashtray. The Ardbeg Perpetuum for example, nice heavy notes of tar and soot on the nose yet dark chocolate and honey on the palate. When you take a sip, has a nice warmth to it followed by smoke.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
