Mugabetown - Whoretownin' At It's Worst.
Nismo fuel pumps are only 275lph or something silly. Sure they bolt in but thats about it. 450lph walbro pump will also cost ~150 bucks less IIRC. If the R33gtst fuel pump mount setup is similar to the R32gtst it's a peice of piss to modify it to fit, though getting to the tank may be harder due to 33's being less likely to combust in a rear end accident.
You could probably easily go smaller injectors (720cc?) and shave off a hundred bucks. Also make sure you buy side feed injectors to suite your fuel rail, with the right size holes etc.
Really need a FPR? Making 300kw's here without one, but maybe there's different stuff on the GTR fuel system?
I wouldn't double the tuning, maybe add only 50%, for flex. You're basically getting two tunes in there. That's assuming you have no issues however, which can quickly add up unfortunately. I mean, best case, just a 98 tune, 500 bucks maybe. Worst case, things to wrong, flex tune, 2000 bucks isn't out of the question, so be ware.
you're also just missing little stuff. Turbo gaskets, new studs, fittings for Ethanol sensor and the like can add up to a few hundred bucks
You'll need to figure out how you're going to get the car to the tuner aswell, Everything you need to do is easy enough to DIY at home (and... satisfying to do, i'd recommend it), but with bigger injectors the car will be undrivable unless you can get the tune adjusted for the injectors. Not sure how easy haltec is to modify
Not compatible? So Walbro over Bosch 040?
If you say so. You've done it recently.
yeah, the Walbro pump is E85 ready and as Pete said flows more than nismo pumps.
It can be fitted in tank too (just like mine)
Yeah, budget for at minimum 2k in tuning costs with eflex
R33 fuel tank is completely different to R32, just FYI.
Not sure how simple it is to mount a walbro/040 in tank in an R33
well as long is its not mounted to the tank floor it'd be easy enough :woot:
    • I keep seeing supercharger kits for these listed on marketplace 😂
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
