Mugabetown - Whoretownin' At It's Worst.
  On 14/07/2014 at 10:54 AM, Ants said:
Ha! Nismo fuel pump with E85? I'd go for Walbro 450 ltr/pm
Tuning $1,000???? Double it
fark,what do they do to cost that much,in the wrong business by the looks of it.
I believe it's an hourly charge, it takes quite a few hours to tune from scratch. A lot of the cost is because dynos are f**king expensive to buy.
this ^ + also dyno maintenance
Just did my tax return online...
Pretty sure that something is messed up. I could buy a good R33 with the return i'd be getting.
So i'm not submitting it yet because i'd eventually have to repay the government money.
I think my employer may have messed up my group cert, my yearly income seems way to low.
How long have you been on site?
  On 17/07/2014 at 9:35 AM, Cadmoon said:
We were, Scott is a power whore so he likes to use archaic outdated measurements :P
HP is a bigger number so sounds faster lol...
  On 17/07/2014 at 9:36 AM, Ants said:
lol although Scottie's machine makes the numbers sound good in either measurements
Mine only makes 340kw's at the moment. Hopefully soon I'll be back over 450kw's
10 months or near enough
My income is too low, but I also figured out the majority reason why the return was so big. Stupid MyTax doesn't let you put your HECS calculations in. Dam. No spare good R33 this year.
  On 17/07/2014 at 10:51 AM, SCR48 said:
Makes my car wang feel bigger though. That counts for something right?
It's like measuring your wang in mm instead of cm just so you have a bigger number :P
myTax automatically accounts for any HECS/HELP - what the estimate says should also be what you are getting back refund wise. Unless you're a shifty bugger
I didn't see anything about it there ants.
anyway, a few quick back of the envelope calculations (don't have pay slips here with me), I have 2 group certs, one for pay on old system and one for pay on new system. The one for the old system is underreporting my income by about $12000, but not my tax withheld. That explains some of the wonkyness.
gotta hand it to the company they really screwed up the pay system transfer something epic now.
yeah I think you should check with the payroll dept.
HECS/HELP IS incorporated in the estimate but they don't give you a breakdown which shits me
We are transitioning to a new payroll system in 2 weeks, I am scared now.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
