Mugabetown - Whoretownin' At It's Worst.
I'm a fan of do it right do it once... But what is right for me o do not know.
Braided lines, new rotors and good pads would likely be up to weekend drives and occasional track work. You need to decide your budget then go from there. If you are happy to spend 4k you can't go wrong with the high end stuff. But much lower spending will also get you results.
I have never met one more angst filled about mods! Lol
Work had for my money, don't want to waste it.
Haven't had a good run of luck with stuff for the car so far either, hence making double sure before I buy anything else.
Pads and braided lines won't make up for the 32 Sumitomos though i don't think, so i'd say i'd need to get something bigger for sure.
So, for research's sake, which companies make good quality brake kits, and which should one stay away from?
Right
So all those people who have D2/G4/K Sport brakes on their cars and say they are good are talking out their ass then?
In a word... yes.
Placebo is a wonderful thing. It makes justifying paying 2k for china crap easy ;)
Are they an upgrade over stock? Sure. Most kits are.
I would go brembo, ap racing, stoptech or something else that comes oem on something that's bigger.
Go with something made by a company that actually makes brakes and have put in the r n d. You get more for your money imo.
Pro tip. A GTR is wasting money at its best!
Splimer ran refreshed stock brakes with no trouble at 296 awkw for years.
AP and Alcon seem to be the top teir. Then probably Brembo and the like. Project Mu is well regarded.
If it was my money I would be checking out those Akebonos that Mike posted 355 is a nice size without going overboard.
This is great value imo. Sure it isnt big name brand, but oem gear quality and big.
And inconspicuous.
http://www.conceptzperformance.com/Cart/description.php?II=3217&Car_Type=300&UID=20140720194920203.9.185.243
Would buy this over d2 etc every time
then don't go for cheap shit Pete.
Get a big brake kit like Brembo F50 with 380mm rotors or Alcon or Endless or Project Mu
Oh I also forgot AP and Willwood
and make it worth it
Have you moved completely to xero in house?
nah mate. Setting up a client on cloud with MYOB accoutright live and also fix up their data which back in the stone ages (few entities involved)
Will get the app for them too
And all bank feeds now ready
34 turbo acquired for my highflow, does this look like it's been modified to anyone? I was under the impression the compression wheel on 34's was nylon not steel.
The fins on the turbine look like the stock design and the rear certainly doesn't look milled out. I would say it is as it left the factory.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
