Mugabetown - Whoretownin' At It's Worst.
Heading up to Howells Knob Lookout tomorrow for a picnic with the family. You get some pretty good photos out there on top of the hill with ranges all around.
Another spot I've been keeping an eye on at sunset is Bullocky Rest. If you can drive out to the tip and take shots from Forgan Road over the water you'll get some awesome shots.
sounds very nice
May head out there at dusk but I believe I would lack the lens to take nice shots from forgan road :(
Hey Ants. If you are after 4 cyl and a bit raised check out a subaru xv. I test drove one recently, good to drive, uses bugger all fuel and has a 5 star Ancap rating! Oh and Hi all, tiring day was tiring!
Edited by Bunta
thanks mate
Will check it out
If you can afford to get yourself out there around 5:30 on a weeknight I can bring 2 photographers from work. We work just around the corner. I'm sure they'd be more than happy to go on a little photoshoot adventure!
I may be able to get out after work some time.
Nice shots.
Here's the route I'm taking tomorrow for a picnic. Anyone got any feedback on the route? I've checked the roads on Street View, but the quality of the images doesn't tell me much about how sealed it is in some parts. Want to avoid any loose stuff.
https://mapsengine.google.com/map/edit?mid=zI1PayDARcBQ.kjTgc9FmU-r0
Edited by Simink
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
