Mugabetown - Whoretownin' At It's Worst.
Yup.
I don't like domestic flights let alone the thought of international, the thought of flying overseas makes me nauseous then a few unfortunate events relating to flying overseas just add to that, needless to say, could not fly Malaysian Airlines even if it is just unlucky at what has happened... But I am sure you will have an awesome trip...
We are contemplating USA end of next year, early 2016... Even then I am tempted to stop in Hawaii for a day or two so that it makes the flight a little bit shorter...
Also... Who can suggest some places I can get a custom colour rattle can made up so I can paint some shiz?
Yeah It pretty much cant be bad, no work for 4 months, hard to go wrong really.
Thats probably better, I wouldnt mind doing shorter trips to different places, but Anna is doing courses while we are over there so it sort of has to go that long. I would like to do like 6 weeks there, 6 weeks in europe, 6weeks in South Africa, ect ect. but yeah at the end of the day I have 6 months of leave built up and I can afford to take it half pay so there is plenty of scope for those other things down the track!
Sounds like a plan! I want to do Europe but doing to start with USA/Canada and then another time go and do Europe (mainly Finland and Germany because relatives over there). I want to go to Japan but not sure about anywhere else in Asia or africa etc.
Autobarn
That's what Bodo said, I have no idea if they will be able to get it close to my Metallic pink/purple pearl since it's two colours on my car to make it what it is but if they can get it even remotely close I will be happy...
Martin let me know of a place in Geebung that may be able to do it and I've heard there is somewhere in Strathpine but not sure where. Gives me a few options at least, hopefully one can get close...
Paint matching in a can will never be 100%
Doesn't need to be, just needs to be close so I can cover the white and grey primer until I am ready for a full spray :)
main thing is they need to be able to scan a sample. not just find a paint code
Yeah, I can take my fuel cap off for them to scan otherwise I have a tin at home which is a fairly close match and was used previously on a door handle when my car was broken into.
Japan aw yiiiisssss!!!
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
    • I'm always a glass half full kinda guy. This will be a great project and the finished product will be awesome.
    • A local that insisted he learned from the best in Australia for RB builds managed to machine a head past the point of saving according to another shop and it dropped a valve too. Ghosted the customer and as far as I know nothing really happened to him. A coworker also recently told a story about owning a Porsche in Germany and running into issues with a dealer tech leaving scratches, oil stains, and missing parts all over his car. I'm not a master tech by any means but at this point I've seen enough expensive mistakes that I'd rather make them myself.
