Mugabetown - Whoretownin' At It's Worst.
howdy peeeps
how is everyone? i have been off the radar for a long time now for various reasons. hope to get back to normal soon. have a tumor in my skull that needs to be drilled out.
ps. anyone know much about the 300ZX Tommy Karia Edition?
My friend had that done when we were in High School. At least they found it, all the best for the procedure, I am sure you will be back at it in no time :)
howdy peeeps
Not good to hear benno, best of luck.
RE the 300ZX, I know that it'd involve just as much engine out.
well it is a lot better then drilling for CSG. I cannot believe how retarded our government is to allow it to happen on our soil. One only has to look to the devastation caused by fracking from the USA. Checkout a doco called Gasland by Josh Fox if you haven't already seen it.
The lure of the revenue is too great.
don't mining companies have an obligation/ responsibility sanctioned by the Australian Government to return the area drilled or mined to an environmentally safe and natural state or this not reinforced as well as it should?
My personal view? I don't beleive there is a strong enough knowledge of the risks to create appropriate conditions to manage those risks.
I would love to hear/ learn more about this mate.
Maybe over a beer (or two) one day :)
Teins have arrived
Inb4 queries about Sydneykid bilstien package - is on hold due to other financial commitments and current coilovers are well and truly f**ked
You didn't consider doing bushes and ball joints first?
  • Like 1
yeah, slowly acquiring the parts Grego (already have the rear subframe bushes from whiteline)
Once I post a pic of my current strut/ coilovers you will understand
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
