Mugabetown - Whoretownin' At It's Worst.
Once I post a pic of my current strut/ coilovers you will understand
You have removed the spring, compressed the shock, sat it on a bench over night and it hasn't rebounded back to its full length or even moved at all? Also the bump stop is completely gone? If no i will not understand.
hmmm......how much would that be for a BNR32?
$350 for the 2 new wheel bearings sitting under my bench, i will even include installation.
Was about $150 for both of mine. I think the 32 should be similar.
f**king apprentices
http://justjap.com/index.php/driveline/driveshafts-bearings/genuine-nissan-rear-wheel-bearing-assembly-nissan-skyline-gtr.html
http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-wheel-bearing-rear-rhs-genuine-nissan-nissan-300zx-z32-skyline-r32-gtr-gts4-r33-gtr-r34-gtr-stagea-wgnc34-260rs-rsfour-p-513.html
f**king apprentices
Sorry, forgot about the GTR tax,
Once I remove them out Greg I will show you
Also, I've never ever changed the coilovers on the GTR and are the same shitty coilovers)I've had since I've owned the car
11+ years old
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
